Aftermarket shift knobs for 2011
Old Feb 26, 2011 | 01:32 PM
rogan01's Avatar
rogan01
Default Aftermarket shift ***** for 2011
Are the shift ***** from some of the 2010 - 2011s I've seen - White, round, with black numbers - available for 2010 - 2011s cars that do not have them stpck? How is the install - hopefully just remove old/insert new.
Thanks.
Old Feb 26, 2011 | 01:37 PM
157dB's Avatar
157dB
Cut & Paste Expert
Yes.
Its a screw and reinstall method.
Easiey peas
Old Feb 26, 2011 | 02:11 PM
rogan01's Avatar
rogan01
Originally Posted by 157dB
Yes.
Easiey peas
Any recommended/available sources for best selection of ***** that are screw/reinstall?
Old Feb 26, 2011 | 02:48 PM
JIM5.0's Avatar
JIM5.0
And can someone post a vid on just how to unscrew the ****? Mine is hard as hell to unscrew off. Is there a setscrew or some grub screw that must be first taken off? If so, where is it?
Old Feb 26, 2011 | 06:26 PM
Hamhole's Avatar
Hamhole
Visit Grabber Pony. I got one from them and I'm very happy with it. The billet aluminum **** was too hot/cold and part of the "5" peeled off my stock ****!
http://www.grabberpony.com/index.php...d&productId=35
You will need an appropriate collar for it as well. Make sure to get the 2010+ collar unless you have a short-throw shifter or some other thing going on.
I used a strap-wrench to unscrew the ****. Ford uses a thread lock compound to keep it on there, so you definitely need the wrench.
Old Feb 26, 2011 | 08:09 PM
JIM5.0's Avatar
JIM5.0
Thanks for the tip. I can actually twist it with my hand, I have the strength to do so. I was just afraid I was marring the threads or post if a grub or setscrew was holding it in place.
As for installing a new ****, what thread lock should be used? Red or blue? Or Purple?
Old Feb 26, 2011 | 08:15 PM
JimmyM's Avatar
JimmyM
I just unscrewed it off.. did that harm the threads? I think that's what most people did (per GrabberPony's instructions)
Thunderball
15
Nov 22, 2015 11:49 PM
Explosive
Oct 2, 2015 07:45 AM
BeatnikFink
Oct 1, 2015 08:00 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
