Tail Light Issues
Old Jun 1, 2011 | 01:08 PM
vic21234's Avatar
vic21234
Default Tail Light Issues
Hey everyone, sorry for the newb question. I'm newer to working on vehicles. One of the bulbs on the rear driver side tail lights is burnt out, causing my left turn signal to blink fast. I replaced the bulb, but its still not working. Where do I look to next?
Old Jun 1, 2011 | 01:19 PM
bakerjd's Avatar
bakerjd
I usually replace all of the bulbs at one time so I can be sure I won't have to replace another any time soon. Maybe start there, another bulb could be on the brink.
Old Jun 1, 2011 | 01:39 PM
adj86's Avatar
adj86
Maybe have wedge something in between the seat and brake pedal (or have a buddy press the pedal) so the break lights stay on, that way you can make sure you replaced the right bulb or that there aren't other ones out. Check your corner signals also, just to be safe.
Old Jun 1, 2011 | 01:51 PM
vic21234's Avatar
vic21234
I know I replaced the right one. When I turn the lights on it is fine. However, when I hold down the brakes this particular bulb will not light up with the other brake lights.
Old Jun 1, 2011 | 02:14 PM
BigDinTexas's Avatar
BigDinTexas
Bad new bulb maybe?
Don
Old Jun 1, 2011 | 02:21 PM
Art161's Avatar
Art161
Maybe spray the socket with electrical contact cleaner. Check for any signs of dirt or corrosion.
Old Jun 1, 2011 | 02:43 PM
GrayPony's Avatar
GrayPony
Check the SJB for water damage
Check power to the socket with a testlight
Old Jun 1, 2011 | 07:23 PM
07 Cervini's Avatar
07 Cervini
what bulb (make and number) did you use to replace the bad one?
Old Jun 1, 2011 | 08:07 PM
Nuke's Avatar
Nuke
Could also be a dirty contact in the bulkhead connector for the tailights. Unplug it, spray some contact cleaner and immediately plug and unplug multiple times to "wipe" the contacts. I had problems with sequentials that was resolved by cleaning the connector.
It's also not all that uncommon to have a bad bulb out of the package.
Old Jun 2, 2011 | 03:28 AM
vic21234's Avatar
vic21234
The light I used was a Sylvania 3057 LL. I'll give the cleaner a shot and go from there. Thanks for the responses guys
