hello, i have a 2007 mustang that the wife bent the driver rear axle shaft. my problem is im trying to get a new one and im being told its a 28 spline shaft not the 31. Is this true. any help would be appreciated.
thanks for your reply, any suggestions as to the best place to get a new axle shaft. I have been looking but i need one with abs or is that something i take off the old one? thanks.
You only need the ABS exciter ring if you have a PonyPackage
with the ABS system.
The "base" model V6 didnt come factory with ABS.
You cant remove the exciter ring from the axle without destroying it...
How did she "bend" it
and how did you determine that it is indeed "bent".
she slid out on a dirt road. went up an embankment. the tire was flat. took it home rotated the wheel and it has a wobble. i am assuming its the axle shaft at that point. vehicle has the pony package. whre is the best place to buy a replacement?
