Axle question
Old Jul 10, 2011 | 08:07 PM
jz's Avatar
jz
Default Axle question
I decided to change my differential fluid today and noticed that I have about .004" play in both axles when pulling on the hubs. I can pull and push on the axles and feel and see the axle move in and out towards the differential. I measured the play, and I'm seeing about .004" on both sides. Is this normal?
Old Jul 10, 2011 | 11:18 PM
scottybaccus's Avatar
scottybaccus
Yep. Perfect. any tighter and they will create friction on the cross pin, building up heat and shedding metal, eventually causing a problem.
Old Jul 11, 2011 | 08:53 AM
legendlime05's Avatar
legendlime05
good to know!
Old Jul 11, 2011 | 05:03 PM
Locke_03's Avatar
Locke_03
Old Jul 11, 2011 | 05:30 PM
Ford_Dude's Avatar
Ford_Dude
ok 4 thousandths of an inch?
I doubt you could even feel that if you were pushing/pulling on the rotor
so I'd assume you had a gauge measuring it
please answer this if you have a gauge out there measuring the play in the rear axles why don't you know this already?
Old Jul 11, 2011 | 05:56 PM
Nuke's Avatar
Nuke
[quote=Ford_Dude;7613938]ok 4 thousandths of an inch?
...quote]
+1
I think the average rear axle has a good bit more play than that; maybe even 8 thousandths of an inch...
KingRando
Oct 1, 2015 11:16 AM
firecoyote
Sep 27, 2015 02:37 PM
Ipaman
Sep 22, 2015 07:01 AM
Sep 10, 2015 08:39 PM
Dragonus18
Sep 9, 2015 01:21 AM
