Tire size question for GT 500 wheels
Old Aug 3, 2011 | 02:31 AM
Bigorangek9's Avatar
Bigorangek9
Default Tire size question for GT 500 wheels
07-09 18x9.5 GT500 wheels, what's the largest & widest tire that will work with these wheels? Originals were 255/45zr18. Should I keep it at that or can I go slightly larger all the way around? Any suggestions??
Old Aug 3, 2011 | 03:48 AM
Tylus's Avatar
Tylus
are all 4 the 9.5" wide?
or do you have the staggered setup with 9.5" and 10" out back?
the 9.5" wide would be fine running 275 or 285 width...the GT500 comes from the factory with 285 width out back on the 10" wides
Old Aug 3, 2011 | 06:54 AM
Nuke's Avatar
Nuke
I believe most tire specs state 285 max for a 9.5" width and 255 min, IIRC. I have a set of 07 GT500 takeoffs and run 275's all around but when I need tires it'll be 255's front and 285's rear. Those 275's up front tramline too much for my comfort.
Old Aug 3, 2011 | 07:43 AM
cheftjpeck's Avatar
cheftjpeck
07-09 GT500 come with 18x9.5 all 4 wheels.. Tires are 255 up front and 285 out back.. The widest recommended tire on that wheel is the 285.. Others have squeezed a nitto 305 rear onto them with very little bulge mainly due to nitto tends to run thinner than other tire brands
Old Aug 3, 2011 | 08:10 AM
Bigorangek9
Thanks, I kinda figured that.
I was getting ready to order some FR500's & a friend turned me onto a set of new in the box GT500 wheels, original from Ford for $550. I couldn't turn that down. Now I just have to decide if I want the 285's out back or keep them the same size.
Old Aug 3, 2011 | 08:24 AM
Nuke's Avatar
Nuke
Staggered 255 front/285 rear will give your car some serious attitude.
Old Aug 3, 2011 | 08:40 AM
Bigorangek9
NorthAmericanTuning
Nov 9, 2016 11:44 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
ccwebb
Aug 11, 2015 06:47 PM
