Billet Grille Question
Those that have purchased the billed grilles with no pony cut out... meaning you have to cut out the original grilles pony, can you see that hole through the new grille? Is it noticeable?
im not a 100% sure on that... i pick up my '12 looks like next week and want to order the grille but from what i have read i thought you cut it off. It may possibly just pop off im not sure. Can someone clarify
For a V6
For a V6
I recently installed a pony delete billet grill for my 06. For it to fit correctly the pony has to come off and in my experience the part of the grill that holds the pony needs shaved down. I figure at some point I'll cut out the honeycomb that isn't essential to holding the billet.
As far as seeing it through the grill you have to be in the right angle to see the original grill.
I installed the pony delete billet grill from American Muscle and cut the pins holding the pony to the original grill and like lunyou said, I had to shave down the grill where the pony was. I used an angle die grinder with a sanding disk to shave the grill down. If you look during the day when the sun is shining on the front of the car you can berely see where it was.
treesloth
Sep 28, 2015 07:03 AM
