Wheel Offset Help
Old Oct 4, 2011 | 04:01 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Default Wheel Offset Help
What is the most aggressive, lowest offset, anyone has used on their rear with a 20 x 10 inch wheel. Im going to attempt a 35 offset. Dont think it will be a problem as the current Shelby SuperSnakes are at 36.7 mm offset on a 20 x 10. Any input would help. I know the sweet spot is 40 - 50 mm but .....................
Old Oct 4, 2011 | 05:23 PM
imsonastie's Avatar
imsonastie
i want to do 19x10.5in +30's. it sucks that you cant go too low with these cars. my 350z took +15s no problem.
Old Oct 4, 2011 | 11:33 PM
MELLOWYELLOW06
That should look wild as hell.
Old Oct 5, 2011 | 11:17 AM
05 Mustang's Avatar
05 Mustang
Joe, seeing that the supersnake rims pultrude outside the fenders just a hair with a 37mm offset, I don't have to tell you what's going to happen with a 35mm offset. Just make sure that since your car is as low as it is, you put on a low profile tire that will keep the fender as far away as possible.
At least with the supersnakes, you could run a 275/35/20 to pull the top of the tire back inside the fender, so that if you hit a bad enough bump, or had your suspension collapse enough, it wouldn't hit. With the rim outside the fender, the tire will be too. You can still install a narrow tire, but it'll still be in harms way if you hit a bad enough bump.
Old Oct 5, 2011 | 02:24 PM
MELLOWYELLOW06
Its 1.7mm difference and running a 285 30 20 tire. I think it should be ok, but we will see
Old Oct 5, 2011 | 03:54 PM
legendlime05's Avatar
legendlime05
i think you couldve paid for my car with how many rims you go through lol
Old Oct 5, 2011 | 05:51 PM
MELLOWYELLOW06
Its a bad addiction!!!!!!!!!
MELLOWYELLOW06
But I think you will like these.
Old Oct 5, 2011 | 07:34 PM
SaddleUp's Avatar
SaddleUp
Just hurry up and tell us already......I wanna know. Lol
Old Oct 5, 2011 | 07:37 PM
09cs's Avatar
09cs
+1!!!
