2001 rims on an 05?
Will 2001 GT rims fit on the 05? I ask because i can get a set with newer tires for 350 bucks. And a buddy of mine has an 04 with the tires i want, but i cant get those tires because the 05+ had the slimmer rims....?
Yes they will fit but in the rear the offset is slightly different so they will poke out slightly.
i can deal with that i suppose, for 350 bucks especially lol.
I see you have a stage III clutch. How drivable is that for everyday driving? I have a stage II Ram clutch and its a little on the heavy side but manageable..
Just how wide are your buddy's rims?
Best of my knowledge, the 2005 & up came with relatively WIDER wheels than the SN95 and NE.
At least you don't have stability control or EPAS, as those newer technologies could be somewhat more sensitive to wheel offset than just you as the driver in normal driving.
Norm
Well it would be different between a GT and V6 I would imagine... But mine is a Stage 3+ which is a non-puck clutch so its very driveable, a tad grabby but nothing that isn't manageable. Apparently the 3 and 3+ are night and day difference as far as driveability. Mainly because the Stage 3 is a puck clutch.
Unfortunately, ford put slimmer rims on the 05+ I guess to help save on costs and whatnot. The Stock 17 tires are narrower and whatnot. My suspension is stock and probably will be for a while. Main reason for wanting these rims is A. the price, And B. i want the tires my buddy has on his 04.
Doesn't look too bad IMO. I will have to be sure to keep a thought on rubbing if i decided to go wider.. I did have a thought to drop the car 1 1/2". How would that affect clearances and what not is something I'd like to know as well.
