Please Help
Old Dec 17, 2011 | 10:49 AM
WatchYaLips14's Avatar
WatchYaLips14
Default Please Help
Last night I was driving home and my mustang started acting like it was choking. It stalled out and I couldn't get it started again. After letting it sit it started but died a few seconds later. The check engine light is on and the ETC (wrench light) as well.. I checked the air filter and fuel filter both are still in good shape. I started it this morning and it idled fine in the driveway but when I tried to drive down the street it started doing the above all over again. Any thoughts on what it could be and possible solutions?
Old Dec 17, 2011 | 11:34 AM
2005Redfire6's Avatar
2005Redfire6
Whens the last time you replaced your fuel filter? Just looking at it doesn't tell you if its ok or not, because they look the same at 5 miles and 100k miles from the outside. And is your MAF connected properly could be possibly dirty, and it wouldn't hurt to clean the throttle body as well for starters.
Old Dec 17, 2011 | 02:51 PM
Nuke's Avatar
Nuke
Check the connector for the MAF and clean the connector contacts. If it happened all of a sudden with no other prior symptoms, I doubt it's a dirty TB or fuel filter. My only wrench light was MAF related.
Old Dec 17, 2011 | 08:08 PM
sbattershell's Avatar
sbattershell
Are the 4.0's electronic throttles, check the throttle body cable, maybe the connector is loose. I would suggest also checking the fuel pump as they will fail suddenly but still function at low pressures. I had a FP go out the car would idle like rough and if I touched the gas it would DIE !!!
Old Dec 17, 2011 | 08:37 PM
Lethaldosage423's Avatar
Lethaldosage423
TPS may be on its way out (Throttle body sensor)
Very common on the GT's
If the Check engine light is still on, scan it. May say the TPS is out of range or something
Old Dec 18, 2011 | 08:11 AM
2005Redfire6
Yes. All 2005+ are
Old Dec 19, 2011 | 11:13 AM
sbattershell
Makes me think the TB connector is loose, I wrote cable but meant wire LOL
Old Dec 23, 2011 | 03:57 PM
Mustangansta's Avatar
Mustangansta
faulty inertia switch? I've had that.
Old Dec 23, 2011 | 04:17 PM
drakefamily2's Avatar
drakefamily2
The only wrench lite i evr had was caused by throttle body, check connections and get a code readout.
