sluggish
Old Dec 19, 2011 | 09:52 AM
HorsePWR07's Avatar
HorsePWR07
Talking sluggish
i have a 07 gt. i have had it for 6 months and live in NY. so basically since i had the car in the summer i would start it up and take off with no problems of any sort. since it is starting to get cold up here in NY when i take off in the morning my car still feels as if the e brake is on. (its not i double check) what could be my problem. i have let the car warm up for 10-20 min prior to leaving. any suggestions?
Old Dec 19, 2011 | 01:28 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
you might get more answers in this section...hope it helps!
Old Dec 19, 2011 | 01:50 PM
09cs's Avatar
09cs
Maybe let the car warm up before you go. Let the idle settle down to normal levels. See if that works
Old Dec 19, 2011 | 02:00 PM
Lem-06's Avatar
Lem-06
Could it be the parking break tsb?
The line freezing up
Old Dec 19, 2011 | 03:14 PM
autos221's Avatar
autos221
dont use the e brake, just leave it in gear
Old Dec 19, 2011 | 06:13 PM
Nuke's Avatar
Nuke
Duplicate thread...
Old Dec 19, 2011 | 07:01 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I'll lock the other one...
Old Dec 19, 2011 | 08:27 PM
MustangFirstCar's Avatar
MustangFirstCar
Disconnect battery for 20 minutes and then try it again.
Old Dec 19, 2011 | 08:37 PM
alkemist's Avatar
alkemist
Make sure that you didn't break your e-brake cable and the brake is still actually set. Do you notice any other drag issues aside from startup? It's a known issue for the e-brake to get frozen during winter.
Old Dec 20, 2011 | 09:38 AM
chain1's Avatar
chain1
Your e-brake cable is frozen. Either don't use the e-brake, or take it in to get it fixed. There is a TSB out there for this. Your other option is to manually dry the cable or just wait for it to defrost with the car on (this can take a while). Don't drive it while its like this though.
