Another possible way to check is chock the front tires, put the tranny in neutral, release the e-brake, jack up the rear, and turn a rear tire. If the other tire turns in the same direction, then it has LSD.
I purchsed a 2008 GT. Kinda new to the more recent Fords, but I thought all Mustang GT's had a Limited Slip Differential. But when I turned the traction control off, I thought only the right rear wheel spun. I'll check it again, but do all GT's have the LSD? Or is it possible mine is broken?
Thanks.
Yes, all 05+ GT's have LSD (limited Slip Differentials). If you're doing a one-wheel-peel then either A) you're not hitting the gas hard enough or B) The LSD clutch packs need to be replaced becasue they are worn out.
I would rather gernade my rear end than my motor. Leaving the TC on with a blower..... its cutting the fuel........not the best thing for a motor with FI. I turn my TC off everytime I drive and just control the wheel spin with my foot pressure. IMO, be careful.
thanks for the advice... I'm gonna try it. Isnt the control on the streering wheel?
I didn't hit it hard. It was raining today so I drove my truck instead!
