Are headlights adjustable??
Old Mar 7, 2012 | 06:00 PM
dennisafrompa's Avatar
dennisafrompa
Default Are headlights adjustable??
I just put the raxion retro lights on my '08 Bullitt. When I pulled into the garage with the lights on one beam seemed lower than the other. The mounting screws (3) are pretty much fixed, so is there an adjustment that can be made?
Here's a pic of the mod.
Old Mar 7, 2012 | 08:30 PM
Rainson's Avatar
Rainson
yes, open the hood, look straight down from top, you will see a screw right behind the headlight on both side. turn on lights and use a screwdriver to adjust angle.
Old Mar 7, 2012 | 09:24 PM
dennisafrompa
Default Thanks.....
...for the help.
Old Mar 7, 2012 | 11:27 PM
DarthV8's Avatar
DarthV8
good luck... i had to pull my whole fascia off to get to 2 of the 4 adjustment screws. such a headache
Old Mar 8, 2012 | 04:15 PM
dennisafrompa
Default Adjust..
Uh, the screws behind the fascia are mounting screws. There is only one adjustment screw as described above. Found it just where stated above!
Old Mar 8, 2012 | 05:29 PM
Rainson's Avatar
Rainson
There's no way to adjust the beam angle by adjusting the mounting screws..All you have to do with the mounting screw is tight them up and don't let the headlights fall off.. There's another screw behind the headlights on EVERY car that allows drivers to adjust beam angle..
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
Drastang
Sep 29, 2015 03:31 PM
