Brake dust?
Old Mar 20, 2012 | 02:45 PM
Antonio323's Avatar
Antonio323
Default Brake dust?
I have a question about brake dust. Does brake dust on a wheel give the wheel a dirty look? The reason I'm asking is because I recently had my brake pads replaced with ceramic pads. The loud screeching sound is unbearable and it seems to be coming from the front wheels. Also, I recently washed my car and I noticed that the front wheels are about three times dirtier than the rear wheels. Is this a bad sign from the brakes and should I take it back to the shop where I had the brakes done?
Old Mar 20, 2012 | 02:50 PM
onederful100's Avatar
onederful100
yes, brake dust makes it dirty.
some aftermarket pads make more dust.
you should look for a pad that makes less dust.
Old Mar 20, 2012 | 02:56 PM
Antonio323's Avatar
Antonio323
Thanks for the quick answer. I understand how some pads make more dust than others, but is it a bad sign if one creates a lot more than the others?
Old Mar 20, 2012 | 03:19 PM
kevinmalec's Avatar
kevinmalec
If all 4 pads are ceramic and the same brand, the brake dust should be about the same on all wheels. The Front brakes are bigger and may work a little harder than the rears, so you may see a little more brake dust, compared to the rears. I have different brand pads on the rear and the brake dust is ridiculous!
Old Mar 20, 2012 | 03:32 PM
Antonio323's Avatar
Antonio323
Yeah they're all ceramic and they're all the same brand. They were all replaced at the same time and I had the rear rotors replaced and the front ones were resurfaced.
Old Mar 20, 2012 | 03:43 PM
gmoran1469's Avatar
gmoran1469
Shouldn't ceramic pads make less dust and less noise?
Old Mar 20, 2012 | 03:45 PM
dcarlinf1's Avatar
dcarlinf1
Generally, the better performance pads make more noise and more dust.
Old Mar 20, 2012 | 03:54 PM
flash gordon's Avatar
flash gordon
Exactly, ceramic pads suppose to make much less dust.
Old Mar 20, 2012 | 04:10 PM
onederful100
I think Hawk makes a low dust pad.
my fronts make more dust too. mine are stock.
Old Mar 20, 2012 | 04:28 PM
vistablue46's Avatar
vistablue46
Cool
..try Akebono´s good stopping power and really low dust
