TPMS Bypass
I want to get some new wheels and the Tire Pressure Measuring System which my car has drives up the price by $400 at tirerack. Anyone disabled it ok know a way around it??
I don't need it I check my tire pressure my self and the OEM one I have on malfunctioned a few times especially when it rained, my tire pressure was fine but the warning message came on.... |
No disable option. Either get the sensors or constantly look at the light.
What year is your car? do you currently have the sensors? you can reuse the stock sensors..
If you can't disable it, couldn't you just take the offending light bulb out of the dash cluster? I think your only other recourse would be a piece of electrical tape large enough to cover the light.
Originally Posted by Andy13186
(Post 7893432)
American Muscle supplies TPMS sensors for 199.00 with their wheel and tire packages. They are the cheapest I have found.
Originally Posted by bigblue95z
(Post 7893457)
^^This. You can buy new bands so you can re-use the stock sensors. That way you won't have to do the calibration as well.
(Post 7893491)
new bands? what are those? i didnt know i needed anything extra to reuse the stock ones
i just press the reset button on the dash and it turns the warning light off.
its free. |
(Post 7893563)
If you're using the same size rim, you should be able to re-use the originals. But if not, you'll need to buy new bands to fit the rim. I got mine at the local DiscountTire for $45 for all 4.
