Mother Nature... She's a b!tch...
I don't know if its an illusion but that one ding looks more like a crater. For less severe dings you could try the heat gun and freeze spray trick. Heat it up then spray it with air in a can or something that comes out cold. Some dings pop right back.
Look it up on You Tube.
About a year ago I had hail damage to every body panel except passenger door and left front fender on my GT. Insurance took care of the $1800 for repair, minus deductable. They were able to use PDR on everything. Had a couple good sized dents on the hood, but not quite as big as yours from what I see in the pics. I tried to run out and cover the car with some thick blankets but had to retreat back inside after taking a couple of shots in the head. NWS reported 1-1/2" dia. hail in my neighborhood.
I've seen dentless repair take smaller dimples out but fail to totally work with stuff like you've got... some dents remained.
My daughter was working in Maryland Heights last night when it all came through. Her car had a glass roof, emphasis on "had". The hail was so hard that it punched baseball sized holes through it. I hadn't personally seen where hail busted windshields 'till last night, not I have.
Good luck
Good luck
Got a check for 2 large for fixing up the dings... they think all of it will be handled by PDR..
Got 500 for the hood alone.. was thinking about the AM 71-73 style Mach 1 hood. Anyone done one of these? Fit / Finish ok?
http://www.americanmuscle.com/kaenen...hood-0509.html
