Weird Electrical Issue
Old May 26, 2012 | 07:09 PM
Young_Gun's Avatar
Young_Gun
Default Weird Electrical Issue
Today, I put my key in, turned it, heard a pop, and the entire car was dead.
No electronics whatsoever. I thought maybe a battery wire had come loose, so I popped the hood, jiggled the sub woofer power wire, and everything came right back to life. All the electronics had reset, but it was all normal.
I drove it around for an hour and had no issue whatsoever.
Any ideas?
Old May 26, 2012 | 07:12 PM
Nyhm's Avatar
Nyhm
Any ideas?
This happened to me once and turned out my battery terminal had a ton a of corrosion on it
Old May 26, 2012 | 07:22 PM
aaquib1992's Avatar
aaquib1992
Still have the stock battery? Is it low on juice?
Usually wonky electronics are a sign of the crap OEM battery dying. When mine was starting to go out, my stereo would randomly shut off and not come back on until I parked the car and restarted it. Or the doors would randomly initiate the locking mechanism (even if they were already in the lock position) when I was driving/sitting there.
So check your battery first and foremost.
Old May 26, 2012 | 07:36 PM
SKAR's Avatar
SKAR
Super Moderator
Make sure your cables are tight, if you wiggled a wire and it "fixed" it then you should obviously track down the loose connection.
Old May 27, 2012 | 08:03 AM
06stangia's Avatar
06stangia
Loose connection or bad battery. The battery post could be bad.
Old May 27, 2012 | 02:22 PM
06stangia's Avatar
06stangia
Hold on why is there a miata lover on here?
Old May 27, 2012 | 06:23 PM
Nyhm's Avatar
Nyhm
Because he's a moderator?
Old May 27, 2012 | 06:31 PM
Young_Gun's Avatar
Young_Gun
Because the Miata is a fun little car for driving through the hills and mountains.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
LiquidDrink
Sep 29, 2015 10:06 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
