AM doesn't disable PATS
So I ordered my tuner today and put in my information for the tunes that I would like, to find out a few minutes later that they can't do it because they can't disable PATS and that I will have to take it to a dyno tuner. So is there another way around PATS to just start the car to make sure it works correctly before I have someone drag it 80 miles to a tuner and does anyone know of reputable dyno tuner shop in the hampton roads area.
I live here in Elizabeth City, and most of the guys in our Mustang club use DTP in Chesapeake VA. I haven't used them personally, but those I know that have used them have only good things to say about them. Here is their link.
http://dtpracing.com/ |
uhm....
wut? Passive anti-theft system has nothing to do with tuning. It alters the PCM which PATS is tied to, but that is verification to allow the injectors and solenoid to start. Tuning won't touch it. Turn with valid already programmed key, done. This is an SCT tuner? Perhaps I'm wrong, and this is the reason for the computer code being necessary, but I didn't believe this was being re-flashed. So long as a valid key is used, it should allow bypassing once you put it in the on position for altering. |
Originally Posted by wayne613
(Post 7969321)
uhm....
wut? Passive anti-theft system has nothing to do with tuning. It alters the PCM which PATS is tied to, but that is verification to allow the injectors and solenoid to start. Tuning won't touch it. Turn with valid already programmed key, done. I'm doing a v6 to v8 swap so my v6 keys will not start a v8 computer/engine operated car. |
Originally Posted by obxdude018
(Post 7969322)
I have always heard they aren't allowed to disable PATS...legally that is.
Well there has to be someone who writes tunes with the PATS off, since there has been so many v6 to v8 swaps have been done in people's driveways.
(Post 7969349)
You need to take your car to a ford dealer and have them program your keys and fobs to the PCM. Should be just an hour labor since you already have keys and fobs.
Originally Posted by danzcool
(Post 7969476)
| All times are GMT -5. The time now is 03:35 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
