MP3 capabilities
Old Sep 22, 2005 | 12:34 PM
BTDstang's Avatar
BTDstang
Default MP3 capabilities
Some of you mentioned on this site that if you have the Shaker 500-1000 system all you have to do in burn a CD of unconverted MP3 files (200 songs) insert it into the system and it will play? I know it probably says that somewhere in the manual, just havent had time to read through the whole thing yet.
Old Sep 22, 2005 | 01:23 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Default RE: MP3 capabilities
I literallycopy/burn the MP3's on my computer to a data CD.... Pop it into my Shaker 500 and they play wonderfully.
I use Roxio CD Creater to do the burn.
Old Sep 22, 2005 | 01:28 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Yep - very cool You can even organize the files on the disc into different folders so you can classify them by genres if you want, and the Skipper.... er I mean Shaker lets you move from folder to folder. I was thinking of getting a shory antenna - but now I just may remove it all together and have it filled in. With nearly 1000 songs loaded in there I should NEVER get bored.
Old Sep 22, 2005 | 01:39 PM
BTDstang's Avatar
BTDstang
Thanks Guys!
Hey sowaxeman,
I was thinking of a shorty antenna too, any recommendations?
Is it something you can do yourself relatively cheap? Thanks - Mike
Old Sep 22, 2005 | 04:17 PM
bahbahblacksheep's Avatar
bahbahblacksheep
ya, the shaker plays mp3s...I've got 6cds filled.
Old Sep 22, 2005 | 04:48 PM
Blankman's Avatar
Blankman
In regards to the antenna. All you have to do is remove it and with some padded pliers (so you wont mar it) and cut the ant. off with a hacksaw to your desired length. Then file down the end a little so it will go back into the brass ball. If you get a loose fit apply just a dab of JB Weld. Takes about 15 minutes. The ball is painted brass so handle it gently. It will just twist off as it is a press fit. Saved yourself some bucks.
Old Sep 22, 2005 | 06:15 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
ORIGINAL: Blankman
What he said - that exactly what I was planning to do.
Urambo Tauro
Jun 10, 2016 03:28 AM
spectreman
Mar 31, 2016 09:26 PM
GLOCKer
Sep 28, 2015 07:36 AM
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
