06 GT missing
Old Jun 30, 2012 | 06:08 AM
furface's Avatar
furface
Unhappy 06 GT missing
06 gt missing on all cyl. changed all coils did not help. intake man was lose could i have cooked the spark plugs? ford racing intake could the gaskets be bad as it was lose for about 2 weeks.
Old Jun 30, 2012 | 07:54 AM
Nuke's Avatar
Nuke
Who's tune are you running with that intake? I'd swap back to the stock tune and airbox first, just to rule tiose out. Pull the plugs and see what you have, too. What coils are you running? Most aftermarket COPs are known to be troublesome. Do you have the OE COPs?
Old Jul 1, 2012 | 06:05 AM
furface's Avatar
furface
it ran fine for 3 months after i put ford racing intake on and dynoed it. tryed it with my stock coils and it did not help. i have new plugs coming maybe i killed the old plugs as the intake bolts worked loose and i did not know it for about 2 weeks and still was driving the car hard.
Old Jul 1, 2012 | 06:30 AM
furface's Avatar
furface
my car has diablo predator 93 tune, granatelli pro series coils, ford racing cams, bbk 62mm throttlebody bbk cold air intake. bbk shorty headers, bbk under drive pullies, ford racing intake, 4.10 gears with auto trans 3000 stall, gt500 lower control arms, aluminum driveshaft, tci streetfighter shifter, the car has 14,400 miles on it.
Old Jul 1, 2012 | 06:39 AM
furface's Avatar
furface
i took the intake off and checked the gaskets they were all OK. ford dealer said fuel pump and injecters OK. i will put new plugs in it and if that dont help maybe another dyno tune and call ford racing tech line.
Old Jul 1, 2012 | 03:43 PM
Simon1's Avatar
Simon1
Put your stock could and throttle body back on. Aftermarket parts like these suck and do not increase horsepower and decrease drivability. If you are getting a miss, what's the symptom? Idle? Cruising? WOT? Vacuum reading?
Old Jul 1, 2012 | 04:09 PM
moosestang's Avatar
moosestang
Who tuned the car? Don't tell me you have all that and some generic tune from diablo?
I agree, granatelli sucks. There are so many people that have had problems with their coils and throttle bodies.
Old Jul 2, 2012 | 02:03 AM
JThor's Avatar
JThor
Check the compression. You can pretty much rule out internal damage that way.
If you burned the spark plugs up, be suspicious of the valves too.
Is it stock control box for the ignition electronics? If not, bring it back to stock.
Good luck!!!
Old Jul 2, 2012 | 02:40 AM
Diabolical!'s Avatar
Diabolical!
Originally Posted by furface
granatelli pro series coils, bbk 62mm throttlebody.
Here are the two most likely sources of your problem. I see you put the stock coils back on. Make absolutely certain that they are properly seated. If that doesn't help, yank the throttle body.
Old Jul 2, 2012 | 05:08 AM
furface's Avatar
furface
car does it at cruising and WOT
