Throttle Body HELP!!
Old Aug 1, 2012 | 06:25 AM
thailey08's Avatar
thailey08
Default Throttle Body HELP!!
Hey guys..new to the forum, i hope someone can help!
I replaced the altenator on my 06 mustang gt, everything is stock, while i was in the process I took off the throttle body and was going to clean it out as well. Well, little did I know NOT to take off the right side cover (where the throttle spring is) now I dont know how to get the spring "re-loaded" The car will crank, but no throttle response. I tried everything I know to do, and there is not much in the way of videos on this! Is that a cover beside the electrical connection that i can open to turn the spring? I need my car!!!
Old Aug 1, 2012 | 07:17 AM
tbar's Avatar
tbar
Maybe look for some BBK throttle body install instruction. I think that piece has to be changed over when you install one. It might tell you how to load the spring.
Old Aug 1, 2012 | 08:20 AM
thailey08's Avatar
thailey08
well, the problem is is that the bbk TB's have an access hole to set the spring. Stock TB's do not.
Old Aug 1, 2012 | 08:56 AM
lawrencecar1's Avatar
lawrencecar1
pop the round cover off and should be able to set
Old Aug 1, 2012 | 09:40 AM
pinn's Avatar
pinn
http://www.bbkperformance.com/download_file.php?pvk=442
http://www.bbkperformance.com/produc...ttle-body.html
not sure if this will help, but it explains swapping the internals from the stock unit.
Old Aug 1, 2012 | 10:21 AM
thailey08's Avatar
thailey08
this is a bbk TB. It has an cap that you can pop off. Stock TB looks like it has one, but I dont want to break it! Is anyone sure that this cap can come off of stock TB?
Old Aug 1, 2012 | 01:26 PM
04AZUREBLUEMACH1's Avatar
04AZUREBLUEMACH1
PM sent with instructions. Yes, the stock cap pops off. In fact, when I bought my BBK Throttlebody, the TPS and Motor Housing were not included... I had to re-use them from my vehicle, so I am sure that the stock cap pops off. If anyone else wants these instructions, PM me.
Old Aug 1, 2012 | 06:00 PM
lawrencecar1
a 2 sec job to set the spring..
Old Aug 1, 2012 | 06:03 PM
thailey08's Avatar
thailey08
lesson learned. i was getting a little discouraged, but it works now! thanks guys for all of your help!
Old Aug 1, 2012 | 06:07 PM
Nuke's Avatar
Nuke
...thanks guys for all of your help!
Newbies that get immediate help have to buy donuts.
