Panhard bar Alignment
Old Aug 23, 2012 | 05:17 AM
Mob Bomber's Avatar
Mob Bomber
Default Panhard bar Alignment
I'm looking into getting an adjustable panhard bar. I was just curious on the center alignment of the axle. Does the adjustable panhard come preset to center the axle or do you have to put it on an alignment machine to see how much you are dog tracking to the left or right? Or can you just take measurements on the ground and adjust it that way? Inputs would be great. TIA!
Old Aug 23, 2012 | 05:34 AM
GT50GO's Avatar
GT50GO
This should explain everything
http://www.bmrsuspension.com/siteart/install/PHR006.pdf
Hope this helps
Old Aug 23, 2012 | 05:56 AM
moosestang's Avatar
moosestang
Hard to believe that using the fenders would be accurate, but I guess it's good enough. The correct way would be find the center line of the body and center line of the rear axle and align it so it's perpendicular.
Old Aug 23, 2012 | 06:03 AM
loaded6shooter's Avatar
loaded6shooter
when ur running wider than stock tires you really don't have a choice but to use the fenders....im running 285s and barely have any room on each side
Old Aug 23, 2012 | 06:17 AM
dennisafrompa's Avatar
dennisafrompa
I use the fenders. It works well.
Old Aug 23, 2012 | 06:30 AM
Mob Bomber's Avatar
Mob Bomber
the bmr link was helpful thanks for the input
Old Aug 23, 2012 | 07:30 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Using the quarter's edge is fine...
Those cars are not far off enough to worry about the exact center of the body.
And besides, depending on what you do to your front end, all bets are off.
Old Aug 23, 2012 | 07:42 AM
05 Mustang's Avatar
05 Mustang
I've installed several adjustable pan-hard bars and used the fenders each time.
Old Aug 24, 2012 | 05:02 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
The plumb bob is the recommended method of measurement, and here's the bar I'd recommend:
http://www.uprproducts.com/mustang-p...rd-bar-05.html
Old Aug 24, 2012 | 06:43 PM
Mob Bomber's Avatar
Mob Bomber
Thanks for the suggestion UPRSharad. I wasn't sure which one I wanted to go for but this one seems like it will give me a lot more room for adjustment.
