here the little video for the exaust fart on idle rev
Old Aug 26, 2012 | 01:14 PM
mighted1987's Avatar
mighted1987
Default here the little video for the exaust fart on idle rev
im not sure this is actually not a normal sound with out cats but I do sure know it worst when im rolling and flooring or down shifting, there is way more bra-pa-pa that can be hear, just cant make that clip too much wind etc.
what you think?
Old Aug 26, 2012 | 01:26 PM
gs462's Avatar
gs462
Believe it or not all cars would do this without mufflers or cats, its a normal sound the above are made to cancel them out. I LOVE when you downshift and it pops like that.
Old Aug 26, 2012 | 01:28 PM
mighted1987
cool then, I might enjoy it more knowing this is a normal sound:P thanks sir
Old Aug 26, 2012 | 01:56 PM
gs462's Avatar
gs462
VERY normal I wish my car did it more Im scared to remove the resonators due to warranty. Its best when you downshift and going down a nice hill.
Old Aug 26, 2012 | 02:00 PM
moosestang's Avatar
moosestang
There must be a million cold start videos on youtube and none I've seen are even close to the backfires you get on a cold start.
off road x pipe.
Old Aug 26, 2012 | 02:08 PM
Antonio323's Avatar
Antonio323
This is something you get with most set ups on a V6, cats or not. Personally, I'm not a fan of it.
Old Aug 26, 2012 | 04:16 PM
mighted1987
Moose, this is a video when car is hot, i know at 100% sure that the back fire sequence from no where is not normal on cold start, but the wide band is telling me that im really lean on cold start, my tuner will send more fuel with the pcm on start, hopefully this will fix it. I just wanted to make sure if it normal what im hearing when reving downshifting etc, im actually going for a pair of reasonator. Just not sure where can i put them..xpipe?
Old Aug 26, 2012 | 04:24 PM
moosestang's Avatar
moosestang
What does your wideband say after the popping stops? Mines stays in the 12's for less than a minute after a cold start, then it's 14.3:1
Old Aug 26, 2012 | 04:52 PM
mighted1987
It stay lean, the mix get perfect on hard acceleration n etc but lean on low rpm cruising. I do not have the exact number cuz my wide band o2 do not work, had to test it on the dyno
Old Aug 26, 2012 | 04:59 PM
2cokeman's Avatar
2cokeman
Sounds terrible but it is normal with the modular engine setup!
