Sponsored by:
Sponsored by:
Finally got my 4.10s in, but we have issues...
Old 09-29-2012, 06:57 PM
Widowmaker[X]
Widowmaker[X]'s Avatar
Default Finally got my 4.10s in, but we have issues...
Finally got around to getting my 4.10s put in on Friday. Started the process of breaking them in as recommended. Babied the car 15 miles home with no issues. Let it sit overnight. Today, took the car out for another heat cycle and noticed a problem...
When pulling out from a dead stop, there is a pretty noticeable vibration that occurs for about a half second. It doesn't happen every single time, but I'd guesstimate around 70%. The problem seems to be magnified when on an incline.
I would akin the feeling to rolling over those rumble strips that they put on the sides of highways to warn you when you are drifting off the road, at a very slow speed. Similar to a chatter. I have also felt it when coming TO a dead stop and one time while starting in reverse.
Gears are FRPP. Used new bearings and seals.
I will be getting in touch with the shop that did the install on Monday. Any ideas on the cause?
Widowmaker[X] is offline
Old 09-29-2012, 08:09 PM
2011scgt
2011scgt's Avatar
was the ford friction modified fluid added
2011scgt is offline
Old 09-29-2012, 08:27 PM
Widowmaker[X]
According to my invoice, yes, but I am not sure how much was added. Could it be possible that more is needed? To add to my original post, it seemed to be worse when turning while beginning to move from a stop, although this may have been my imagination.
Old 09-29-2012, 08:59 PM
2011scgt
2011scgt's Avatar
i just wonder if it was not added and you paid for it
2011scgt is offline
Old 09-29-2012, 09:21 PM
white08gt
white08gt's Avatar
go to a parking lot and do tight figure 8's in each directions. sounds like your clutches in rear end are the culprit. i've had the same problem after changing the rearend fluid, showed up more after sitting awhile and turning right. just had some more friction modifier
white08gt is offline
Old 09-29-2012, 10:12 PM
Widowmaker[X]
I should add that the car is an auto. I've heard the figure 8 thing mentioned before. I will give that a shot tomorrow.
Old 09-30-2012, 04:16 AM
SteveB_RET
SteveB_RET's Avatar
The Friction modifier is needed only to quiet the clutches in the rear end when turning. Not have it will not cause what you are describing.
SteveB_RET is offline
Old 09-30-2012, 04:40 AM
caaraa
caaraa's Avatar
Looks awesome, thanks mate.
caaraa is offline
Old 09-30-2012, 12:34 PM
Widowmaker[X]
I can replicate the problem when moving very slowly (under 5 mph) in both drive and reverse. I do not notice any issues when moving faster than this.
I tried doing some tight turns today, no improvement.
Old 09-30-2012, 02:44 PM
FrostByte
FrostByte's Avatar
Take back to installers shop. Shouldnt be doing that.
FrostByte is offline
Quick Reply: Finally got my 4.10s in, but we have issues...
