clutch or transmission
Old Oct 7, 2012 | 07:54 AM
mighted1987's Avatar
mighted1987
It a 1.7k clutch that what my uncle told me when they swapped my
Engine.. ****ing sad dont have another 2k to throw on a clutch + a noisy tranny
Old Oct 7, 2012 | 08:43 AM
JDWalton's Avatar
JDWalton
Ok, here is the most common missed item I see when people start getting into heavy mods. Your exhaust, especialy with the long tube and supercharger, is making a TON more heat then your stock exhaust. So much so that the factory plastic clutch line becomes soft and doesnt fully dissengage your clutch.
http://www.lethalperformance.com/jhr...e-upgrade.html
https://mustangforums.com/forum/8004881-post55.html
You may want to replace your slave cylinder as well. there not that expensive, and good insurance.
Also, look for a twist in your in your input shaft, your pushing enough power now that you can actulay warp it.
Old Oct 7, 2012 | 09:17 AM
mighted1987
Thx walton. Is there a way to see if the clutch line is my problem or should i just order the jhr line right away?
Old Oct 7, 2012 | 10:07 AM
moosestang's Avatar
moosestang
Originally Posted by Diabolical!
Your clutch fluid is your brake fluid.
Thank God someone said it!!!!!
Old Oct 7, 2012 | 10:19 AM
P Zero's Avatar
P Zero
Originally Posted by mighted1987
this is starting to happen alots:
drive around, get to a stop or a light, first gear, full feet-pression on clutch, rpm will bounce and either want to die(like if the clutch wasnt correctly engaged) or the car will slowly try to move forward so I gotta put bigger pressure on break, it like if I was half way clutch release ready to move...I dont feel anything weird while pushing the clutch, but the car react like if my feet wasnt fully on it...any idea? man my transmission is about to die with all the bearing I hear making noise, cant believe my ****ing clutch is about to go too? argh
oh and sometime my shifter is stock in my gear, like already said in another post, cant get my freaking gear out without pulling HARD on the shifter.
Man your trans is so ****ed. If it's getting stuck in gear AND noisy, it's toast. Get a new one ASAP.
I had a T-5 come apart on me onthe freeway. Is was not so cool. One of the bearings came loose and locked up the trans while I was going 70. O.O then I slid to a stop, luckily I managed to get it off of the roadway. Flat spotted my tires too. sucked.
Old Oct 7, 2012 | 10:54 AM
mighted1987
But do you think my clutch is having some issue too?
Old Oct 7, 2012 | 01:23 PM
JDWalton's Avatar
JDWalton
If it only happens once the car is warmed up, or more so when it is hot outside, do the cable first.
If your having a hard time with it feeling like it is stuck in gear, pull it into neutral and pump th clutch pedal 5 or 6 times then hold it in and see if it goes into gear easier.
If it is all the time, look for warping in the input shaft.
Do you know what year your swap kit came from? Mid 08 was when they started shipping our transmissions with beefed up syncros and forks.
http://promotionpowertrain.com/TRANSMISSIONS_.html
Old Oct 14, 2012 | 12:36 PM
mighted1987
can the clutch line be changed without removing everything?
somehow, it happen when the car get hot, when I first leave with it cold, it seem to shift fine, then after 10-15 minutes, it start to get stuck in gear and not properly disengage/engage.. my uncle say it impossible cause last month when he swapped engine they checked my clutch and it was all perfect.
Old Oct 14, 2012 | 12:57 PM
JDWalton's Avatar
JDWalton
It's a pain in the but cause of where it is, however the external cable can be changed with motor and trans on car.
Old Oct 14, 2012 | 02:28 PM
mighted1987
yes im talking about the cable you refered me from lethal.. was wondering if I could try this solution before having to do a 1-2k labor jobs$
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
wraith777
Sep 28, 2015 10:49 AM
MacSerio
Sep 27, 2015 01:05 PM
