Dyno an Automatic?
Old Oct 19, 2012 | 12:44 PM
rogan01's Avatar
rogan01
Default Dyno an Automatic?
Read article about dynos that says dyno testing, etc. should be done with the car in as close to 1:1 ratio as possible - would guess this is 4th or 5th gear on a 2011 - 2012 GT. Makes sense I guess...
Just wondering how this is done on an automatic?
Old Oct 19, 2012 | 12:53 PM
TRexGAWD's Avatar
TRexGAWD
Pretty simple, the shift points are just changed around for dyno purposes so it stays in the appropriate gear at a low speed.. Almost like locking it in 3rd..
Old Oct 19, 2012 | 12:57 PM
Derf00's Avatar
Derf00
Gentleman's Relish
or, can't you just manually shift it to 3rd or whatever gear is required and leave it there?
Old Oct 19, 2012 | 01:02 PM
TRexGAWD's Avatar
TRexGAWD
Most will not stay in 3rd when you go WOT from a low speed.. The point that is changed is the 3-2 downshift..
Old Oct 19, 2012 | 01:06 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Ah, gotcha. I forgot the 2011+ have that sport auto instead of 1-2-3-D (+ OD for 5) like the 05-2010
Old Oct 19, 2012 | 03:07 PM
nolimits's Avatar
nolimits
Depends on the car. Some can be altered in tuning, some have a stable manual mode, and some just need to be throttled carefully to avoid a downshift. I've usually done my pulls in 3rd to avoid a long, drawn out pull. I've compared pulls with different gears and the hp/tq doesn't vary enough to worry me. It's more about having the right amount of resistance...a higher hp car will want a higher gear or you rip through the pull too fast to get a decent reading (and also can get spin). Dyno manufacturers recommend 1:1 to maintain consistency from one shop to another.
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
