Question about Changing rim size
I don't know who to believe.... please help
I have a 2013 Mustang V6 Convertible with the Pony package
I am thinking of upgrading my rims from the stock 18 inch to 19 inch when my turns require replacing
The agency guys told me not to upgrade them as that might damage my transmission although from what I know from working in an accessories shop 3 years ago, you can always upgrade the rims by 1 or inches safely without hurting your transmission
My friend tells me that I can upgrade the rims, but I need to change the gear ratio to match the rim size, and that would void the warranty
He said that if I upgrade the rims and don't change the gear ratio, the car will run fine but in bout 3 years the transmission will break
I don't know who to believe, and with that said, it seems it is best to stick to the stock rims or just get a diff. model 18 inch rims ?
Please explain with some details
thank
These are the current rims that I have:
thank
Damage the transmission? No.
The added rotational mass may make your car feel a tad slower, but unless you datalog like a maniac, chances are you won't even notice that. How does transmission damage even make sense to your friend?? You might end up having to get new TPMS sensors if you do not take the ones off of your current rims, but again that is up to you and whether or not you mind a TPMS signal being lit up on your dashboard.
At most, your speedometer will be slightly off, but again we are talking like .5-1 mph. Barely noticeable. You will not sustain transmission damage from any of this, and changing gear ratios is also unnecessary. People do this for performance gain quite often (as a steeper ratio will give you better acceleration with slight decrease in top speed) but that is unrelated to changing rim size.
About half of this forum runs aftermarket/larger rims than stock. None of them have reported transmission damage. Sounds like your friend has no idea what he's talking about
My friend claims to be the guru of cars as he is always buying totalled cars and restoring them then selling them
so are those TPMS sensors cheap and easy to get at the dealer? easy to install by any tire shop or does the agency have to do it?
Thanks for the clarification bro.
Dealership/tire shop will also have the syncing tool necessary to sync your sensors back up to your car. Any tire shop could do this though, I regularly let my local tire rack/discount tire do it when I switch between summer/winter tires.
And you may not even need to get the new sensors synced. I bought some Roush take-off wheels/tires/TPMS from another V6, and I never needed to sync the TPMS sensors. I have a generic Ford reset tool from when I owned a 2011 Focus, but I never had to use it for the Mustang! I guess the computer can figure it out all by itself!
Typically when you change rim O.D. you also adjust with the tire O.D. to maintain an overall O.D. equivalent to the factory tire O.D.. NO impact to anything.
Are you sure you want to go to 19's? First, there's not as much selection of tires in 19". Second, more sidewall = more sexy and going to 19" will REDUCE sidewall. I'd have 17's or 16's on my Stang if I could at this time.
Maybe paint them black? what do you guys think?
Berry, the pic in my signature line is my 2013 with 19x9.5 SVE Drifts and Nitto 275/35/19 Tires.
If you have an SCT tuner you can change the rim/tire size setting in the vehilce with the tuner, or take it to your dealer nad ask them to reflash with the new spec.
You 'car guru' friend doesn't know his head from his *** when it comes to newer cars. Back in the day to have more accurate speed reading you had to make small adjustments with actual parts, but since OBD II, it is all computerized.
You will not harm your transmission or drivetrain just from switching tires and rims, it will get ruined from showing off your new wheels by during burnouts and donuts every chane you get to show off, and even than it woul dtake a lot of abuse before you fried anything in the drivetrain.
