For street use, is there really a huge difference when it comes to adjustable or non adjustable? Sorry to hi-jack, I really wish I knew more about suspension related stuff. I know I need a panhard bar but, have no clue where to begin... Any help is appreciated
The adjust-ability gives you the ability to adjust where the axle is aligned. The lower the drop, the more you need to move it so the adjust-ability helps make sure you can put it in the right place.
Double adjustable? I just went with BMR. We'll see how it goes.
If you got the BMR PHR006 bar you'll be just fine...it has one adjustment & (2) jam nuts off centered just alittle that makes it very simple to center the rear axle under the car. It comes with instructions that explain eveything.
I had to install a "double adjustable" PHB once......what a freakin nightmare.
