Problem with SYNC text messages say its from ME!
I'm using a droid raz through SYNC in a 2013 Ford Mustang and SYNC shows my name and phone number as the sender for every text message, which makes replying impossible and I have no idea who sent it. It was working fine up to about a month ago. Anybody having same issues? not sure if the problem is on the phone or sync side!
Yugi
Yugi
Yugi
Yugi
sorry, couldn't resist...
have you tried unpairing the device then re-syncing it?
tried syncing a friends phone as a test?
Might also need an update or a reset
Yugi
Yugi
Like the other two mentioned, your phone should be soft reset, and deleted from SYNC. A soft reset is done by holding the POWER button and VOLUME DOWN key on your phone for about 10 seconds. The phone should power up immediately after. Go to the Bluetooth settings on your phone and delete the SYNC connection. You'll also need to delete the phone from your SYNC system by selecting the following options: PHONE > SYSTEM SETTINGS > BT DEVICE > DELETE DEVICE.
Follow these instructions to pair the phone once you've completed the previous steps: http://support.ford.com/sync-technol...our-phone-sync
If it continues to show your information instead of the senders, verify that your firmware version supports text messaging: http://support.ford.com/sync-technol...atibility-sync Make sure you check the box that says SMS TEXT MESSAGING (on the left). If you recently updated your phone, this could change the way it interacts with the SYNC system.
Kim
750BOSS
Wheels & Tires
Sep 18, 2015 06:14 PM
yourmom6990
Sep 14, 2015 10:52 PM
