oops, now what?
Old Aug 31, 2013 | 11:44 PM
defiance's Avatar
defiance
Default oops, now what?
Last night on the way home from work my car throws a check engine light. So today I plug in my tuner and run diagnostics. Tuner states no trouble code found....so I unplug and restart everything, once again, no trouble code found. So just for the hell of it I select the function to erase trouble codes, hoping that would clear up a glitch of some sort in the tuner and well....that function actually worked as intended, it cleared my check engine light.
So did I permanently erase the code or is it going to come back?
Old Sep 1, 2013 | 07:59 AM
Chazman_1962's Avatar
Chazman_1962
disconnect the battery for a few minutes this will reset everything, if there is a problem code it should come back
Old Sep 1, 2013 | 12:31 PM
Steven Bannoura's Avatar
Steven Bannoura
If if you're car driving fine, i wouldn't worry about it, just wait and see if the engine light comes back on. I wouldn't worry about it
Old Sep 2, 2013 | 10:30 AM
defiance's Avatar
defiance
Thanks, I will give that a shot.
The car does drive fine, no changes that I can feel, and I drive a lot, my commute to work is 30minutes one way.
Thanks guys
Old Sep 2, 2013 | 07:34 PM
petrock's Avatar
petrock
Erasing trouble codes with a scanner or other tool will have the same effect as disconnecting the battery for a couple minutes. Benefit of the tool is speed (no wait time) and reliability (you don’t have to guess that you waited long enough). I’d use the scanner if you have it available.
Old Sep 3, 2013 | 02:49 AM
808muscle's Avatar
808muscle
Could have been the gas cap code. Happens when you dont put it on exactly right. Happened to me the first week I owned my car and filled up with gas. No big deal.
warthrone
Nov 22, 2006 10:21 PM
freewilly
SVT Forums
Sep 29, 2006 05:25 PM
fordluvr
Mustang Videos
May 17, 2006 08:29 PM
Ditch
Dec 28, 2005 08:24 PM
five0
Mustang Videos
Jan 26, 2005 03:32 AM
