TPMS problem
Old Sep 23, 2013 | 08:01 AM
GTjoe49's Avatar
GTjoe49
Default TPMS problem
I have winter tires mounted on Ford Mustang 18" 5-spoke wheels. Before I removed them last spring, the TPMS light came on. All pressures were OK. When I mounted my summer wheels, the light went out.
As it is almost time to put the winters back on, I have been thinking about how to locate the wheel giving out the signal. If I just roll each wheel out one by one and lay them next to the car as its running, will the tell tale sensor show up?
I know I can just mount them and go to the shop, but I am curious.
Thanks for any suggestions.
Old Sep 23, 2013 | 08:45 AM
Nuke's Avatar
Nuke
I'm assuming that both your summer and winter wheels have the sensors in them. Personally, I don't give a ratz azz about the TPMS system and I'd ignore it. But you should be able to have the offending sensor identified with the sensor training tool.
Old Sep 23, 2013 | 08:53 AM
drukkosz's Avatar
drukkosz
Hi,
Every time you change your wheels you need to sync your TPMS.
You will need that tool, They also have a video how to do it:
http://www.americanmuscle.com/tpms-tool.html
hope it helps
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
