Quick turn signal blinker
Old Nov 1, 2013 | 01:21 PM
ThaiCobra's Avatar
ThaiCobra
Default Quick turn signal blinker
SO, when i turn on my left turn signal it clicks really quickly. Which I know means something is out or dieing.
Well I replaced the front turn signal bulb, and the rear turn signal bulb, and it's blinking super fast. Any ideas?
Old Nov 1, 2013 | 02:26 PM
vixr's Avatar
vixr
arent there two flashing bulbs in the back? Mine has three...
Old Nov 1, 2013 | 02:31 PM
AMWill's Avatar
AMWill
Former Sponsor
What year Mustang do you have OP? If it's an 05-09, you should have two bulbs in the rear tail lights. Check the extra when you get a chance. That's probably the faulty bulb.
Shane
Old Nov 2, 2013 | 01:36 PM
ThaiCobra's Avatar
ThaiCobra
Thanks for the replies guys,
Its an 07GT. The rear assembly has 3 main bulbs and a 4th smaller reverse bulb. When the turn signal is activated, only the outer-most bulb blinks, just one bulb. And I have replaced that bulb and I'm still having the turbo blinker.
Could it be the fuse?
Old Nov 2, 2013 | 02:06 PM
R1nStang's Avatar
R1nStang
i had an issue similar to this on my 06. fast blink. rear bulb wasnt coming on. changed the bulb out...same issue. wasnt the bulb it was something in the wiring. i guess dirt got in the connector and the bulb lost the connection when in the connector. inserted and removed the bulb about a dozen times and it cleaned off the terminals and didnt have any issues afterwards
Old Nov 2, 2013 | 03:14 PM
Lem-06's Avatar
Lem-06
hmmm...i know atleast the middle and outer lights are supposed to blink...somethings wrong somewhere....
Old Nov 2, 2013 | 08:23 PM
Art161's Avatar
Art161
Replace the middle bulb.
Old Nov 2, 2013 | 08:59 PM
steev's Avatar
steev
The middle and outer lights should be blinking, which is gonna be your problem...
Old Nov 4, 2013 | 04:57 PM
ThaiCobra's Avatar
ThaiCobra
Got it, duh. it was the middle bulb. I think what confused me was it was still lighting up when braking (double filament)
so thanks guys.
svfetter
Oct 5, 2015 11:39 AM
Seanam
Oct 4, 2015 10:15 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
Sep 25, 2015 06:30 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
