preowned bama tuner???
I know somebody who wants to sell his bama tuner. It came from 2011 mustang. I have 2013.
What needs to be done in order for it to work on my car? Is the tuner locked?
Thank you for all the info
The tuner will be "locked" unless he returned his car to stock - if his car still has a tune installed from that tuner, it will be married to that car. For it to work on your car, you'll need to get a set of tunes from Bama or your tuner of choice written for your car (assuming it isn't locked). If it is locked, you'd have to send it in to SCT and have them unlock it, and then get the tunes for your car.
If it is locked, I wouldn't bother buying it. The cost to 'unlock' a tuner is somewhere around $150 IIRC + another $150 for tunes for life from AM. If the cost of the tuner is 125-150 + 150 +150 = 425-450 you may as well buy a new one directly from AM that already includes tunes for your car.
The tunes from someone elses car will NOT work on your car unless your PCM code is identical.
+1 on ensuring it's unlocked.
Then you'll need to order custom tunes. The tunes for his '11 will not work on your '13 unless they're canned tunes from the handheld manufacturer (but you said BAMA so it likely has HIS custom tunes for HIS '11).
No way! Unlocking the tuner is simple. You just need to make sure that it has been done. It is well worth the savings to verify, then all you need is $150 for new tunes and you're set.
Its easy to check if its been unlocked. Plug it into your ECM port and it will ask if you want to lock in the new VIN once it realizes its not the same VIN. Its really no pain at all. Then you have the cost of the new tunes, but it is still cheaper.
However, if the device is already unlocked you could get into that device for $150 less. Look into the device options and see if it's locked or unlocked and we'll go from there! Whatever is easier for you, just let us know and we'll gladly help you out.
-Dan
