car won't shift
Old Jan 30, 2014 | 12:23 AM
copestang's Avatar
copestang
Default car won't shift
I have 08 mustang gt 5 speed, every time i get on it or down shift (to pass or speed up) it lock me out where i can shift,( engine dont shut off) untill i shut the car off and restart it than everything alright again
Old Jan 30, 2014 | 06:45 PM
WJBertrand's Avatar
WJBertrand
Unintelligible
Old Jan 30, 2014 | 07:20 PM
copestang's Avatar
copestang
what would casue my car, not to able to shift
Old Jan 30, 2014 | 09:52 PM
dlazrael's Avatar
dlazrael
Need a better description of the problem, so many variables at play troubleshooting would be like playing pin the tail on the donkey at the moment.
Temperature
Speed
Mileage on the car
Clutch (stock/AM)
Funny noises
Grinding
How often, every time or once in a while
Codes?
Etc...
Old Jan 30, 2014 | 09:58 PM
copestang's Avatar
copestang
90,000 miles, stock clutch, hurst shifter,no nosies, no codes, 4:10, tune, it do it everytime I get on it hard
Old Jan 31, 2014 | 11:36 AM
Midasboot's Avatar
Midasboot
So after you accelerate hard you can't get the car out of gear, but when you pull over and shutdown then restart the engine everything works fine?
Sounds like something mechanical is binding under hard acceleration. You might want to check trans mounts, and double check your shifter linkages to the AM Hurst shifter
I might be mistaken, but I don't think any gen mustang has shift lock out features like GM products. Anyone else know?
Old Jan 31, 2014 | 02:10 PM
2005Redfire6's Avatar
2005Redfire6
From what I can understand it won't let you get out of gear when you get on it until you shut the car off? I don't see how shutting the car off will have anything at all to do with it not letting you in/out of gear since that aspect is all mechanical.
Old Jan 31, 2014 | 02:38 PM
akdoggie's Avatar
akdoggie
Sounds like something is binding in the drivetrain. Clutch? Bad pilot bearing?
Old Jan 31, 2014 | 02:59 PM
Art161's Avatar
Art161
One possibility is a bad engine mount.
Old Jan 31, 2014 | 04:54 PM
copestang's Avatar
copestang
yes, that the only way to get my car to shift again, is to pull over shut the engine down, than restart it, also it will let me put the car in reverse
