Tire pressure
Old Apr 1, 2014 | 03:54 PM
l00kitzzlilcj's Avatar
l00kitzzlilcj
Default Tire pressure
I have bigger tires on my gt. Front is 245/45/19 and rear is 275/40/19. The recommended pressure was 32psi while the wheels were stock. Maybe this is dumb, but i suppose since the tires are bigger they should be running on more than the stock pressure? It hit me today when I checked the pressure in them... they were at 40 (max is 50). I figured 37 all around would be good. What would be best to get the longest life out of them?
Old Apr 1, 2014 | 08:47 PM
Nuke's Avatar
Nuke
You realize there are always tradeoffs... Higher pressure = rougher ride, negative impact on handling, less rolling resistance.
I typically go by the pressure stated on the door placard or on the tire's RECOMMENDED pressure and then adjust up and down by 2 PSI until I find what I prefer. Why worry about saving about 6 months of tire life by giving up handling on a performance car? I typically run at 32-34 PSI but each tire brand/model can be different. And remember that tire pressure will change about 1 PSI for every 10 degree F change in ambient temperature.
Old Apr 2, 2014 | 04:54 AM
2005Redfire6's Avatar
2005Redfire6
I generally do 32-33 in the rear and 35 in the front.
Old Apr 2, 2014 | 05:37 AM
07 GT E UPP's Avatar
07 GT E UPP
32 psi all around for me..
Old Apr 2, 2014 | 12:42 PM
l00kitzzlilcj
Yes i know that. I used to ride 30/31 F/R, but when i thought to check my pressure yesterday to see what exactly was in there, I then realized I put bigger tires on than stock. I'm looking to keep my bigger tires the same way. Do I have to add more air, like maybe 35/36? There should be a chart for this lol.
Old Apr 2, 2014 | 12:47 PM
l00kitzzlilcj
Stock tires or no?
Old Apr 2, 2014 | 12:57 PM
krazykevin's Avatar
krazykevin
I run 31 psi with 275/40r18. The tire wear seems even after ~10k miles so I'm sticking with that.
Old Apr 2, 2014 | 01:43 PM
RetiredSFC 97's Avatar
RetiredSFC 97
When I don't put the same tires back on a vehicle I go by the max pressure, then back it off until I'm happy with the ride and tire wear. This may take a month or so to find the sweet spot but that's the only way I know how to do it.
Old Apr 2, 2014 | 06:32 PM
jz78817's Avatar
jz78817
the recommended pressure doesn't really change based on tire width.
Old Apr 2, 2014 | 08:20 PM
AzPete's Avatar
AzPete
For tread wear you want the tread flat. Draw a chalk line across the tread and roll the car forward enough to wear the chalk off. Adjust pressure until you get an even pattern.
Another way is to roll over damp pavement and look at the print it leaves on dry pavement. Adjust for flat pattern.
