Poor Engine Performance
Old Apr 30, 2015 | 08:12 AM
cruisin5268d's Avatar
cruisin5268d
Originally Posted by MIKE562
I didnt know you were the thread police
You never asked.
Seriously though, I think everyone on a forum should be empowered to give a little nudge to someone when they create duplicate threads across the site.
Old Apr 30, 2015 | 01:45 PM
Nuke's Avatar
Nuke
Before anything else, I'd reclean the TB and I'd disconnect the battery for 30 minutes to reset the Adaptive Learning on the PCM. This often helps restore from a lot of granny/city driving settings. Also, after a reset, you may notice some rough engine operation the first few dozen miles.
Old Apr 30, 2015 | 01:48 PM
Nuke's Avatar
Nuke
Isn't this a duplicate of your post in the S197 main forum?
Old Apr 30, 2015 | 06:02 PM
CMcNam's Avatar
CMcNam
Surprise!
Originally Posted by cruisin5268d
You never asked.
Nudge, push, trip, kick, whatever. I don't think there's a rule against it.
Old Apr 30, 2015 | 06:38 PM
MIKE562's Avatar
MIKE562
No its just an illusion
Old Apr 30, 2015 | 06:55 PM
JimC's Avatar
Super Moderator
Cruisin might not be the "thread police" but..........
Please don't start multiple threads on the same thing. No need to clutter the board.
Threads merged.
Old Apr 30, 2015 | 07:44 PM
MIKE562's Avatar
MIKE562
Thank you
Old May 1, 2015 | 12:10 PM
Nuke's Avatar
Nuke
Any update on your issue (the car, not the duplicate threads. 😛 &#128526?
Old May 1, 2015 | 11:49 PM
MIKE562's Avatar
MIKE562
I haven't had much time to check the spark plugs or the COP's. I will get to them by the the end of this weekend (I need a to get me a torque wrench!). I did check the fuel injectors to make sure they're all firing, which they are. I've also checked for vacuum leaks and have not found any so far.
I just bought a can of Seafoam, but I'm not sure how I feel about feeding it through the vacuum lines, so I'm going to pour it in the gas tank instead.
I will post an update once I pour Seafoam and check spark plugs/COP's
Old May 2, 2015 | 07:33 AM
Nuke's Avatar
Nuke
Regarding the SeaFoam, you'll need to ensure the ratio is appropriate and then run that mix until you're down to about 1/4 tank to get the most benefit. sometimes it takes a 2nd attempt if it's a stubborn, fuel system-related problem.
djbigskrilla
Sep 20, 2022 01:04 AM
Calizic
Aug 28, 2015 01:46 PM
inyadreems
Aug 21, 2015 09:10 AM
Pain.
Aug 7, 2015 10:48 PM
