Light problem after Engine swap?
Old Jun 2, 2016 | 07:55 AM
Topless Stang's Avatar
Topless Stang
Default Light problem after Engine swap?
Hey guys,
Had engine issues in my 6er, so I had a replacement engine swapped in. I picked the car up last week and just now noticed that for some reason I now have DRLs. Has anyone seen this before? From what I gather DRLs can be programmed into the BCM or a module is needed. I had neither done....is there any way they could've got some wiring messed up and caused this? I do have an after market kit installed for Hi/Low & Fogs...so they might have gotten that crossed too, but I was thinking that if they did the lights would be always on, however, they just come on with the car. Fogs works with the switch as intended, but my Low Beams stay on as long as the car is on. HELP!!
Old Jun 2, 2016 | 03:06 PM
Derf00's Avatar
Derf00
Gentleman's Relish
When they did an engine swap, what year was the donor car and did they swap the PCM or the engine harness or both?
Old Jun 2, 2016 | 04:22 PM
Topless Stang
My car is an '06. Donor was '09. The only thing swapped was the engine. I kept my old engine harness, ECU, PCM, BCM, etc..
Old Jun 2, 2016 | 05:29 PM
09GT/CS's Avatar
09GT/CS
Depending on the shop they may have reflashed. We used to do that a lot when doing engine swaps. If they flashed a tune that had DRL that could be the issue. DRL is controlled by the BCM but the PCM tells it when your in drive to activate them. I don't think you can reprogram the BCM you just change whether the PCM sends the signal id have to check the manuals though which I don't have at home here.
Old Jun 3, 2016 | 07:48 AM
Topless Stang
It was dyno tuned while there so I know they tinkered with it....but he says he only manipulated ECU stuff....nothing with lights.
mitchell1963
Mar 14, 2016 12:32 PM
clowe1965
Carolina Regional Chapter
Mar 13, 2016 04:02 AM
Shaq74
Mar 11, 2016 02:19 PM
scooter3
Mar 11, 2016 09:01 AM
Redneck1465
Mar 8, 2016 02:04 PM
