P2247
Old Oct 24, 2020 | 06:49 PM
winkawak's Avatar
winkawak
Default P2247
bank 2 sensor 1 oxygen sensor reference voltage was not within acceptable limits
anyone knows where this sensor is located?
Old Oct 24, 2020 | 07:28 PM
winkawak's Avatar
winkawak
Okay i found it but how do i reach it from below? K member and lower control arm seems to be in the way. The other end of the connector is behind the engine between firewall i cant see or reach......
is it safe to drive with an bad o2 sensor? possible engine damage? i have a trip tomorrow about 1k miles. Can i wait till then?
Old Oct 25, 2020 | 02:20 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
You might wanna get it fixed before going on such a long drive. If the engine's running lean on bank 2 (driver's side), you could potentially cause some damage. This guide will help you troubleshoot it:
https://www.obd-codes.com/p2247
The O2 sensor itself may be OK but the wiring to it may be damaged.
Henry5.0
Sep 3, 2019 05:00 PM
cobraetti
SVT Forums
Dec 28, 2008 05:36 PM
ROB 98GT
May 23, 2008 03:04 PM
jlw2387
Mar 12, 2008 04:27 PM
93lx
May 10, 2005 01:09 PM
