Need help with this
Old Oct 19, 2021 | 10:25 PM
4.0_v6_mustang's Avatar
4.0_v6_mustang
Default Need help with this
So my 4.0 V6 Mustang got into a accident and it was hit from the front of the car and so the airbags activated and everything but now that I'm trying to fix it gas doesn't want to get to the motor, what could it be ?
Old Oct 20, 2021 | 02:10 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
The collision has probably tripped the fuel pump inertia switch. It's a safety item that was installed to prevent a fire if an accident causes a fuel leak. There's a button to the front of the hood opening handle behind the driver's side kick panel. If you can push it in, it means the FP inertia switch has indeed been tripped and doing so will get you going again.
Old Oct 20, 2021 | 05:14 PM
4.0_v6_mustang
Then what would I have to change to get it running again ?
Old Oct 21, 2021 | 02:48 AM
Dino Dino Bambino
Nothing unless there's a component that's been pushed in far enough to interfere with the engine.
Old Oct 22, 2021 | 07:52 PM
4.0_v6_mustang
Ok so we were able to get it started and all but now when we turn it off it dies out completely but we already fixed the terminals and the battery, what could it be now ?
Old Oct 22, 2021 | 11:52 PM
Dino Dino Bambino
You might want to check the engine grounds.
locobabyboy7
Jun 11, 2013 06:58 AM
supersnake427
Sep 1, 2008 02:36 PM
murfs66
Jun 27, 2008 01:36 PM
saleen87
Apr 27, 2008 08:18 AM
kenco
Mar 5, 2006 02:10 AM
