2005 Mustang GT window issue
Old Aug 5, 2024 | 06:39 PM
05superchargedGT's Avatar
05superchargedGT
Default 2005 Mustang GT window issue
Hello All.
I have had my 2005 mustang GT since new.
just today at a car show my windows would not stay up when I turned the ignition off.
basically they would go down upon turning my ignition off and opening my door.
have un-plugged the battery and also tried the window reset.
any suggestions would be greatly appreciated on what the issue is.
Thank you
Old Aug 12, 2024 | 01:52 PM
HypromanGT's Avatar
HypromanGT
By window reset, I assume you are referring to what is discussed here:
https://www.allfordmustangs.com/thre...selves.212204/
This is the first time I have seen the "de-initialization" part, which could be something to try if you haven't yet. Also interesting to see someone reference cell phone interference as a reason for discontinuing the feature (hadn't heard that on before either).
Beyond that, I'd be suspicious of the Smart Junction Box that's famous for water damage (it controls a lot of non-engine electronics). That's behind the front passenger-side kick panel. I'd inspect that for signs of corrosion/water damage.
Old Aug 12, 2024 | 02:34 PM
05superchargedGT
I do believe the issue lies within the voltage level of the battery.
I left my battery on charge over night and re tested the windows. All works fine now with a fully charged battery.
my battery is 5 years old so maybe time for a replacement.
Old Aug 17, 2024 | 01:48 PM
jjjefferson's Avatar
jjjefferson
Angry New wrinkle to old problem
So I just ran into a new wrinkle to this window losing its mind issue on my 2007 Mustang GT Convertible. I'm the original owner so I've run into this issue a few times over the years after batteries died in the middle of winter (when its parked and covered). Usually the normal "reset" procedure fixes it, but today, (with a well charged battery) the window on the drivers side drops down when opening the door...butttt.....after a few seconds of the door being open....the window goes back up as if the door was closed. So I lower the window, run the reset, and it does it again...and again. I have to lower the window, close the door, roll the window up and climb out the passenger side to lock the damn thing. Passenger side behaves normally.
I will attempt the "de-initialization" next, thanks for the post! However, if that does not work, any ideas on what would cause the window to just go up while it is open???
Thanks.
JJ
englishguy
Aug 4, 2022 10:29 AM
Vincent Surmont
Convertible Tech
May 28, 2017 07:16 AM
tonybonnie2011
Mar 17, 2013 02:31 PM
tonybonnie2011
Mar 16, 2013 06:59 PM
mustangfan305
Dec 4, 2012 04:45 PM
