Intermittant issue no crank
Old Sep 23, 2024 | 10:19 AM
Mustang1301's Avatar
Mustang1301
Default Intermittant issue no crank
2013 Ford Mustang GT 120,000 miles first major issue.
Car starts up perfectly fine in morning and most of the time. Evening cold starts is large hesitation start up every day. What I'll do is prime the fuel pump by turning key then off and then prime again its way more instant startup.
The issue pattern is it'll start perfectly fine in morning but if i stop somewhere for even a minute and restart there's no crank at all. When this happens, the computer says to check charging system. Battery is less than a year old. Zero corrosion on battery terminals.
I've replaced the purge valve twice and now has an oem purge valve. I'm guessing bad fuel injectors or fuel pump. Anyone have any idea? I just purchased new stock oem Fuel Injectors - EV14 - 34lb (11-17) 5.0 and I'll install them this weekend and see if that clears it up. I also get 10miles to the gallon but think it needs to be around 14miles per gallon. Always 93 octane.
Old Sep 28, 2024 | 09:20 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Have you scanned the ECU for fault codes?
Old Sep 28, 2024 | 10:53 AM
Mustang1301
It turned out to be the starter. Thanks anyway.
zea14
Nov 18, 2022 10:25 AM
T_Grant
Feb 10, 2021 06:22 AM
gil57usa
Oct 26, 2017 08:09 AM
campbell990
Sep 6, 2008 08:19 PM
tidrow55
Jun 20, 2008 02:15 PM
