Some questions
Old Nov 29, 2005 | 07:49 PM
steve59's Avatar
steve59
Default Some questions
Hi all
I'm new here. I bought recently a 2005 4.6 with only 2500 km's on the clock, and I'm happy with it. Not really a sportscar, but nice performance and a nice sound for cheap money.
I have some questions.
- The lights are not really bad, but not good either. I think about to switch to more powerfull bulbs (100 W?), but the plastics of the lamps let me hesitate. Are there other solutions?
- Chip-tuning. According to the manual, this car is build for less fuel quality (only 87 octan???), so chiptuning should be possible? But I'm not sure about specs of fuel (american/european?)
- As I'm happy with this car, I think about keeping it and improve it here and there OR to wait for the new 5.0. What do you think, keep it or tune it?
- I have strange problem. Sometimes the car don't start. I just have to take my a$$ from the seat and it will start. What about this?
- I've seen in the photo-galery someone who fitted a navigation-system (I think it was Pioneer?). Are there some easy and not to expensive solutions for upgrading to navigation, while keeping CD-mp3-charger OR installing an I-pod?
Ok, lot of questions :-)
Steve
Old Nov 29, 2005 | 09:01 PM
chrisc's Avatar
chrisc
Default RE: Some questions
alright, i will take a shot at these questions...
lights: yes you can change them to much higher brightnesses, i'v seen many different bulbs available but i never saved the sites
chip tuning: yes you can retune this car, and it's not too hard either. most mustang sites sell the xcal2, this should o the trick
modding: i think you are talking about the 07 shelby cobra 5.4L engine? if you are, i dont think they will be very easy to get ahold of, so i say mod this one, if you want hp you can always s/c or turbo
starting problem: i have no idea, that is just weird, maybe you should ask your dealer
nav system: there are a bunch available, i have a pioneer one myself. most of them (i think all of them but i cannot be too sure) play cd/mp3/dvd. as for the ipod there are a lot of other systems that can integrate it into your sterio, i know the monstor one is the officially supported one by apple. as for the non-expencive solution to the navigation system replacement, pretty much every one runs for about 1000+ and the pioneer one that fits right into the entire slot is around 1.5K
hope it helps, chris
Old Nov 30, 2005 | 12:00 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Be careful changing out the headlamp bulbs.
There are a few aftermarket bright white bulbs out there.. and they WILL make a difference. BUT beware of upgrading to a higher voltage bulb as the reflector is a cheap plastic that will melt.. AND.. the new mustangs have a "Smart Panel" in the electric system which very well could shut down your headlamps if they draw too many amps.
Saleen is making true HID Headlights for this mustang.. complete Headlight Assembly... if you REALLY want to upgrade... THAT is the way to go!
Personally, I found my headlights to be plenty bright.. but their aiming sucked... I adjusted them higher and more stright out forward and am quite happy with them now.
Old Dec 13, 2005 | 08:53 AM
steve59's Avatar
steve59
first thank you for your answers and the tips.. I had not much time to reply earlier.
can you tell me which one it is? Please? How much time will it take to change the unit?
About tuning, the problem is that with the very strict limitation it is not possible to make much more than chip-tuning.
But probably to upgrade to higher octane (95 or 98 oct is usual here) will help a bit?
Old Dec 13, 2005 | 10:57 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
ORIGINAL: Professor Wizard
Ditto on this - apparently Saleen doesn't re-aim (or failed to do so correctly on mine [&:] ) the headlights after lowering the car. My headlights were pointed VERY low to the ground. After a little tweaking, I am fairly happy with the lights.
I MAY upgrade to the Saleen HID's, but then again my car is a show car which equates to minimal driving at night anyway - so hard to justify.
Old Dec 13, 2005 | 01:08 PM
chord509's Avatar
chord509
Check out http://www.superhids.com/. They have a MUCH cheaper solution than the $1100 Saleen solution. The H13 model is a replacement bulb for the '05 Mustangs.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
