MyColor dash,,,
Old Dec 22, 2005 | 05:02 PM
Sonic3v's Avatar
Sonic3v
Default MyColor dash,,,
i seem to be LOST in my settings, i had it set to a custom color and now i cant figure out how to get to thr primaries...all it allows me to do is adjust the R G B seperatly..if i remember right there was a setting before that, that has colors already set...or maybe i was dreaming...but yea.. if there is anyone know how to revert back to it? and vise versa
Old Dec 22, 2005 | 05:06 PM
GGIII's Avatar
GGIII
Default RE: MyColor dash,,,
If you're done adjusting the RGB values, hit Info to reset back to the primaries.
You should be able to scroll with them by using (but not holding) the button.
Old Dec 22, 2005 | 05:07 PM
Sonic3v's Avatar
Sonic3v
thanks ill check that out, and how would i get back to rgb if needed?
Old Dec 22, 2005 | 05:12 PM
Sonic3v's Avatar
Sonic3v
hmm that didnt work, when i press info it just goes back to the main display >.<
Old Dec 22, 2005 | 05:14 PM
GGIII's Avatar
GGIII
Right, now you press setup untill you scroll through the MyColor options. Hold on... *goes out to car*
Old Dec 22, 2005 | 05:18 PM
GGIII's Avatar
GGIII
Okay, you hit setup untill you see the Mycolor color or a message saying HOLD RESET TO ADJUST MYCOLOR. Then just hit (not hold) reset to cycle through the colors.
Old Dec 22, 2005 | 05:19 PM
Sonic3v's Avatar
Sonic3v
yea but that is for the RGB, wasnt there a setting that just had normal solid colors?
Old Dec 22, 2005 | 05:25 PM
GGIII's Avatar
GGIII
Yes. If you're still in the RGB, you should hit setup untill you see a message saying something like "Hold Reset to Confirm" after you go through the Green Color. Do that, and hit setup untill you see the regular primary colors again.
Old Dec 22, 2005 | 05:40 PM
Sonic3v's Avatar
Sonic3v
yea im giving up on this one haha...man i wanted my red dash back...
Old Dec 22, 2005 | 05:42 PM
GGIII's Avatar
GGIII
lol
Okay, when you scroll over, what shows on your screen? Does it say HOLD RESET TO ADJUST? or does it show the R G B values?
