Hood Questions
Old Jan 14, 2006 | 12:32 AM
dcranford's Avatar
dcranford
Default Hood Questions
Hi all
I have my baby put away for the winter up here in Minnesota, but im looking for the mods im going to be buyin with my bonus check in february.
First thing im thinking about is a new hood....I like the gefracing hood and the champion fiberglass shelby hood....however I hae 2 concerns.
1. Do I need hood pins if im not racing it?
2. It looks like neither hood has the windshield washer nozzles drilled out.
Anyone have any answers to this question?
Here are the links to the hoods in question
Gefracing hood
Champion FiberGlass Shelby
Old Jan 14, 2006 | 12:42 AM
spyder7724's Avatar
spyder7724
Default RE: Hood Questions
the gtr hood from rk sport looks identical but has the nozzle holes already cut and is functional. you will want the pins though. the increased air under the hood causes it to start lifting at about 60mph. not a saftey problem i don't think but nonetheless i didn't like it. now it's stable to 120mph so far. look on ebay sometimes you can get them cheap from rksport direct. got mine for 219+shipping.
the hoods you are looking at may not need pins if they aren't functional. cutting holes for the nozzles is not that hard if you have a dremel and patience...but i would do it before painting just in case.
Old Jan 14, 2006 | 12:45 AM
dcranford's Avatar
dcranford
I guess I just dont like the tall cowl on the GTR hood from RK sport.
Im going to have a body shop do the paint and install, but I just am scared to have them drill into my hood.
Also im not a fan of the hood pin look, and I dont plan on going 120MPH other than for a few seconds maybe once in a blue moon.
However if its a safety issues I guess it needs to be done....
anymore opinions? Id like to hear them from people that have done this already
Old Jan 14, 2006 | 03:39 PM
dcranford's Avatar
dcranford
anyone with one of these hoods that can answer the questions in post #1?
Old Jan 14, 2006 | 03:46 PM
andyman's Avatar
andyman
Are there anymore pictures of the hood you posted? i kinda like that hood..
Old Jan 15, 2006 | 05:00 PM
dcranford's Avatar
dcranford
bump
Old Jan 15, 2006 | 09:38 PM
Corpo's Avatar
Corpo
my hood starts to lift and shake at 120, i plan on hood pins but i intend to goto the track. i don't expect to go faster then that
Old Jan 17, 2006 | 02:08 PM
my05mustang's Avatar
my05mustang
ORIGINAL: dcranford
Hi all
Gefracing hood
I just received my hood I ordered from Champion. The hood was well made with just a little extra prep work. When I ordered it I asked if hood pins are needed and they told me that with the factory hood dancing around at high speeds the would recomend hood pins on any aftermarket hood. As for the washer sprayer there are 2 small indents on the surface of the hood where they go. It will need to be drilled to install them.
Old Jan 17, 2006 | 06:04 PM
sngsam's Avatar
sngsam
I don't know if this helps or not but I have a Steeda "functional racing hood" (fiberglass). I doesn't seem to "need" pins but I like em so I got em. The washer nozzles are moved to under the "lip" of the cowl by the windshield. I think if you are going to spend that much on the hood you probably like the aggressive look and you can't go wrong with old school hood pins. There are some new ones.. One guy on this forum is nuts for 'em but old school looks so aggressive. Just my two cents. Good Luck and send pics!!!!
Straight Flushes,
SAM
Old Jan 17, 2006 | 07:50 PM
dcranford's Avatar
dcranford
my05mustang
Do you have the pics of your Champion Shelby hood? Is there like a mesh where the vents are? Also what hood pins should I get I see that ford racing has some, but im trying to get as close to a 1967 Shelby GT350 as possible.
So I think im leaning toward the champion Shelby hood, anyone think the Gefracing hood "legend" is better?
