Satellite installation
Old Jan 23, 2006 | 02:51 PM
STL_Atty's Avatar
STL_Atty
Default Satellite installation
Has anyone else installed a satellite receiver? Was it difficult to hide the antennae and power wires? I got a Serius receiver over the holidays and would like to avoid wires running all over the place, as well as paying someone to install.
Old Jan 23, 2006 | 06:20 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: Satellite installation
Plastic dashes these days are nothing but snap in clips - barely any screws anymore. Just start pulling gently and work your way around the entire piece and you should be able to remove enough pieces to find all sorts of nooks and crannys to hide/route your wires through. It just takes patience and A LOT of flexbility to get upside down and below the steering column to see what your doing
Old Jan 23, 2006 | 06:48 PM
STL_Atty's Avatar
STL_Atty
Thanks for the words of encouragement SOWAX. Luckily (well, in hindsight, unfortunately) I've torn enough dashes out of enough cars to be be confident on that end. My concerns were more along getting the receiver antennae to the roof and whether the power cord is long enough to get to the outlet in the console. The former is more worrisome than the latter - I'd really like to avoid putting it on the outside of the car.
I see another thread has started along a simlar topic .. so feel free to ignore this one. My feelings won't be hurt too badly [X(]
Old Jan 23, 2006 | 08:29 PM
mash2k's Avatar
mash2k
I have installed a few of these things and usually you do not have to take the dash apart. A good place to put the antenna is right next to the passenger side window pillar right on the dash. The wire is so thin that it can usually be snaked around and hidden into the trim. Too easy.
Old Jan 23, 2006 | 09:24 PM
karazuba's Avatar
karazuba
i ran my sirius antenna behind the dash, under the console, under the backseat (1/2" showing in the gap, but covered with a matt black wire loom for looks), up the trunk sidwall, and out onto the top of the trunk just where it meets the window (right in the center underbeath the carlise glass logo). Centered, out of the way, and actually decent looking.
Old Jan 23, 2006 | 11:52 PM
Cruehead's Avatar
Cruehead
I ran my Sirius Satellite power wire along the side trim, through the armrest, into the outlet inside the arm rest. The antenna wire followed the power wire through the armrest, then went out the back of the armrest, under the back seat, and up into the rear deck. Here's a link to the post with a pic. No wires can be seen, and the unit itself is mounted in a decent spot.
https://mustangforums.com/m_933910/m.../tm.htm#936743
Old Jan 24, 2006 | 12:42 AM
mash2k's Avatar
mash2k
Hey sowaxeman, I see you are from naptown. I was born and raised there. Whereabouts are you from?
ORIGINAL: sowaxeman
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
