Question about traction control...
Old Feb 4, 2006 | 09:50 PM
StevesGT's Avatar
StevesGT
Default Question about traction control...
Still feeling out my new '06 GT, its been raining most of the day, so I figured its a good time to try out the traction control with out beating it too hard. So I punch it in first gear and the rpm's just zing up, quickly enough that I thought I might redline it, so I hit second, but drive it normally from that point on. But at no point did the traction control intervine. I did a system diagnostic, and everything checks out, so whats up with it?
Old Feb 4, 2006 | 09:58 PM
antiv6's Avatar
antiv6
Default RE: Question about traction control...
did you press the trac control button b/c that turns it off
Old Feb 4, 2006 | 10:00 PM
StevesGT's Avatar
StevesGT
Thanks for the reply,.....no, I never mess with it.........
Old Feb 4, 2006 | 10:43 PM
Newbreedgt05's Avatar
Newbreedgt05
The traction control is supposed you to spin up the tires with the tc on, if the conditions are right. It somehow determines if the conditions are wet and then will make the traction control active. If the traction control is on and it determines that the conditions of the road are dry, then it will allow you to spin the tires somewhat. It could be that your computer didn't have time to determine that the conditions of the road were wet and just allowed the tires to spin. It's kind of hard to explain, but I read about in the 2005 mustang brochure from the dealer. I couldn't find it in the 2006 brochure.
Here it is.
Old Feb 4, 2006 | 10:47 PM
StevesGT's Avatar
StevesGT
Huh......OK,....thanks. I guess your right, it happened so quickly I cought the computer sleeping. It all happened in a matter of moments.
Old Feb 4, 2006 | 11:38 PM
Secter's Avatar
Secter
yea, i got a nice burn with trac control on today and it was dry. didnt do it intentionally, just never had my car peel out yet, and it just hit me. kinda thought the same thing you did, but its normal
Old Feb 4, 2006 | 11:56 PM
LesteR723's Avatar
LesteR723
mine kicked on once- the onboard computer dinged and said traction control active or something along those lines- about the only thing it did was cut my RPM's down enough to stop the spin on and off and on and off... but it works!
Old Feb 5, 2006 | 01:43 PM
ren274u's Avatar
ren274u
i noticed that it kicks on when i dont want it, and when i first got the car i completely fishtailed and it didnt come on. Good thing i knew how to correct myself or my rings would be banged up at the curb
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
