Informational Documents
I found these from various places thought it might be good to put them all together.
2005audio_diagnostics
Amp_luggage_comp
Mustang_Owners_Manual
Rear_shelf_speakers
airbag
airbag saftey
A Piller
Audio Connector
Camber Adjustment
Centerpanel
Cluster Removal
Clutch 4.0
Clutch 4.6
Clutch Controls
Console
Cluster Description
Diagnostics and Testing Brakes
Diagnostics Wheels and Tires
Door Speakers
Door Trim
Driveshaft 4.6
Exploded View Diskbrakes
Exploded View Exhaust
Exploded View Rear Suspension
Foglamps
Foglamps
Fogs
Front Subframe
Fuel Lines
Fuel Tanks
Fusebox
Fuse Info
Headlamps
Headlights
Headliner
Instrument Panel
Interior Trim
Message Plugs
Panel Registers
Parking Brake Adjustment
Passenger Airbag
PVC Valve
Power Steering Exploded
Quarter Panel Speakers
Radio Removal
Rear Quarter Convertible
Rear End 7.5
Rear End 8.8
Rear Lamp
Rear Seat
Front Bumber Removal
Grill Removal
Rear Bumper removal
Rocker Panel Removal
Spoiler Removal
Seat BAckrest
Rear Seat Coupe
Front Seat cushion
Front Seat exploded
Seat Backrest
Complete seat removal
Seat Cushion Removal
Seaker Enclosure
Brake Specs
Steering Wheel
Strut
Subwoofer
Audio Connector
5 Speed
VIN Codes
4.0 Water Pump
4.6 Water Pump
Amp_luggage_comp
Rear_shelf_speakers
airbag
airbag saftey
A Piller
Audio Connector
Camber Adjustment
Centerpanel
Cluster Removal
Clutch 4.0
Clutch 4.6
Clutch Controls
Console
Cluster Description
Door Speakers
Door Trim
Driveshaft 4.6
Foglamps
Foglamps
Fogs
Front Subframe
Fuel Lines
Fuel Tanks
Fusebox
Fuse Info
Headlamps
Headlights
Headliner
Instrument Panel
Interior Trim
Message Plugs
Panel Registers
Passenger Airbag
PVC Valve
Radio Removal
Rear End 7.5
Rear End 8.8
Rear Lamp
Rear Seat
Grill Removal
Rear Bumper removal
Spoiler Removal
Seat BAckrest
Rear Seat Coupe
Front Seat cushion
Front Seat exploded
Seat Backrest
Seaker Enclosure
Brake Specs
Steering Wheel
Strut
Subwoofer
Audio Connector
5 Speed
VIN Codes
4.0 Water Pump
4.6 Water Pump
ORIGINAL: cstigger04
Quarter panel speakers????? Do the 05-07 Mustangs have them, because mine dosen't and it looks as if there is no room for anything under the panel without some serious mods?
Probably for the verts. No rear deck for speakers in a vert.
Thanks for the info. I've got a buzz in my passenger side speaker and was thinking about getting at it this weekend. Nice not to have to go in blind.
[IMG]local://upfiles/28784/9EA2DB46AA3D47DCB24274C74762B9F3.jpg[/IMG]
Updated TSB List from Ford on the 05/06 Mustangs...
Technical Service Bulletins
2005 MUSTANG - US (English) 2.28.06
06-5-4
* PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING
06-4-9
* A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS
06-4-7
* TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
06-4-2
* BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
06-4-1
* RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-3-13
* FUEL FILL SLOW, OR DIFFICULT TO FILL
06-2-9
* DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
05-25-15
* MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
05-24-6
* CONVERTIBLE SYSTEM CONCERNS
05-22-8
* WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-21-2
* LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
05-20-2
* REAR AXLE NOISE
05-19-10
* LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10
* BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
05-18-7
* WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-12
* SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
05-15-13
* FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12
* FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005
05-15-2
* GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4
* WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
* INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-14
* CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
* FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
* INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-6
* EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
* AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
* AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-3-1
* MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
* MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
* WELD BONDING PROCEDURE
04-24-14
* GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
* REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-9-6
* BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
06-5-4
06-4-9
06-4-7
06-4-2
06-4-1
06-3-13
06-2-9
05-25-15
05-24-6
05-22-8
05-21-2
05-20-2
* REAR AXLE NOISE
05-19-10
05-18-10
05-18-7
05-16-12
05-15-13
05-15-12
05-15-2
05-14-4
05-10-19
05-9-14
05-9-11
05-9-3
05-8-6
05-7-3
05-6-15
05-3-1
04-26-22
04-26-16
04-24-14
04-24-5
04-9-6
From Rannascar....
A listing of the Cods from the PCM and their meanings...
http://www.nology.com/pdfandzipfiles/obdiicodes.pdf
