Flames out the pipe
I want to find a kid to install to shoot flames out the tail pipes and what kinda price range we are lookin at
RE: Flames out the pipe
Thats going to be a very small kid, to be able to fit in the tailpipe. Then you'll have to find a tiny little flamethrower for him/her to use, Don't know if it can be done-LOL
I heard somthing about nitrous or a propane kit with a spark plug i was just wondering if anyone knew where to find one
$40 for the "kit", or you can buy a toggle switch and a spark plug :D
please not its illegal in most if not all states... so watch the cops! |
i have seen a lot of kits, but none of them can be used while driving
Say no to rice |
It wont even work.. And if it does it would be real dangerous... Those type of things dont work well with cat converters
That is an old school hot rodder trick. Mostly used on lead sleds from the 50's. What ya did was drill a hole in the exhaust tip about 4 inches back for a spark plug and an inch behind that for a propane jet. You then set up a coil for the plug and a switch that would activate the coil and a servo for the propane. I doubt you could do it to a stang because of the muffler location. Now days that would look like you were adding fried rice to you're stang.[sm=americanasmiley.gif]
I remember those things at car shows when I was a kid. One guy had sparkplugs in the the exaust pipe and would keep the choke on the carb creating a lot of unburned gas to come out of the pipes to be ignited. It took a lot of work to get a flame out and the car was not being driven. I have never seen a propane/gas injected setup.
ORIGINAL: MusiccityGT That is an old school hot rodder trick. Mostly used on lead sleds from the 50's. What ya did was drill a hole in the exhaust tip about 4 inches back for a spark plug and an inch behind that for a propane jet. You then set up a coil for the plug and a switch that would activate the coil and a servo for the propane. I doubt you could do it to a stang because of the muffler location. Now days that would look like you were adding fried rice to you're stang.[sm=americanasmiley.gif] |
