Help needed!
Old Feb 23, 2006 | 06:29 PM
SpikeGT's Avatar
SpikeGT
Default Help needed!
hey guys, I'm trying to install Steeda udp's but the crank pulley wont come off. i'm using a 3 prong puller but it wont budge, any suggestions, I dont want to mess something up.
Old Feb 23, 2006 | 07:02 PM
SpikeGT's Avatar
SpikeGT
Default RE: Help needed!
never mind I got the pulley off. I'm stupid.
Old Feb 23, 2006 | 08:36 PM
Hiboost's Avatar
Hiboost
How hard was it to change?
Old Feb 23, 2006 | 10:20 PM
SpikeGT's Avatar
SpikeGT
Once I figured out what I was doing wrong it was easy. If you have the tools it is easy. The problem I had was with the pulley puller. Everything is on now and everything is all good.[sm=icon_rock.gif]
F00Mustang's Avatar
F00Mustang
forgot to remove the center bolt huh?
Any clearance problems, I've heard some people have some issues.
Old Feb 23, 2006 | 10:31 PM
SpikeGT's Avatar
SpikeGT
ORIGINAL: F00Mustang
no I removed the bolt, I just didn't have the tightening bolt on the puller pushing against anything solid. the threads on the end of the bolt actually were damaged, I was scared to death I messed up the threads in the crankshaft, but they were fine. So I just slipped a socket over the end of the bolt and the pulley came right off very easily.
I have 0 clearance issues, the alternator bracket bolt they gave me in the kit clears the waterpump pulley by a good 1/2 inch or so.
Old Feb 23, 2006 | 11:45 PM
BlackB-U-TEE_06's Avatar
BlackB-U-TEE_06
Old Apr 4, 2006 | 12:58 PM
raybroussard's Avatar
raybroussard
Hey what kind of puller did you use?? did you attach to the outside of the pulley or the inside, I am having trouble getting mine off!! I got my puller on but with only two jaws and put some serious torque on it and it did not budge and that is even tapping on the pulley with a rubber mallet hoping it would give while under tension but no luck. Please let me know how you did it...
Ray
djbigskrilla
Sep 20, 2022 01:04 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
MusicCity615
Sep 27, 2015 12:53 AM
Sep 1, 2015 08:16 PM
defarmer
Aug 13, 2015 06:40 AM
