2012 Base V6 Upper Grille Removal?
Old Jan 1, 2013 | 08:19 PM
Paul_VS's Avatar
Paul_VS
Default 2012 Base V6 Upper Grille Removal?
How is it done?
Old Jan 2, 2013 | 06:12 PM
Shelty's Avatar
Shelty
if its anything like the 05-09, remove the rad cover by removing the plastic scrivits, and it should clip in, push the tabs in and it should slide out.
Old Jan 2, 2013 | 06:14 PM
Paul_VS's Avatar
Paul_VS
Thanks!
Old Jan 2, 2013 | 07:55 PM
Shelty's Avatar
Shelty
yup the plastic push pins on the rad cover are easy to get off, pry the center up with a screw driver then gently pull it up and it should pop out. then it should lift off and you will see the plastic tabs that hold it in.
funny just how much of this car is held together with plastic and metal clips vs nuts n bolts.
Old Jan 2, 2013 | 10:00 PM
Paul_VS's Avatar
Paul_VS
I was looking at it and thought "Nah.... it can't just be held on with clips.... there must be some screws I can't see somewhere"
vbonina
Jul 22, 2018 08:12 AM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
kevans79@yahoo.com
Aug 18, 2015 09:01 PM
StickShifty
Jun 26, 2015 07:47 PM
