2011 drive shaft
recently purchased a 2011 convertible. I have read a lot about the drive shaft not being so great. since I plan on keeping the car for a long time would it be wise to replace the driveshaft ? the car is just for cruising no hard driving.it will see some interstate driving, 75 -80 mph. I don't mind the cost, I just want to be safe. thanks ,scott
You would be fine without an aluminum driveshaft but, go ahead and change it. I had no problems with my factory driveshaft but changed to an aluminum one 'for peace of mind'. I did noticed the aluminum driveshaft was smoother and more quiet than the factory one
75-80 you should be fine. I've had mine up to 120 and it is still holding together. Allegedly, these are speed limited to 112 MPH because of the driveshaft. There is a video on youtube of a guys breaking apart at 135..you should check it out.
this is what I have, not sure if they have it for your year
http://shaftmasters.com/4ullialdrfom1.html
